TwinTurbo.NET: Nissan 300ZX forum - Balance tube 'O' rings ? (n/m)
ttz'in (norcal)
on April 07, 2016 at 12:13 AM
Re: Re: Did you check the two connectors next to the fuse box?
posted by Metacom
on April 06, 2016 at 07:02 PM
no start after Plenum pull.
tinner
10:57:26 04/05/16
Re: no start after Plenum pull.
ttz'in (norcal)
11:49:02 04/05/16
Re: Re: no start after Plenum pull.
tinner
11:57:11 04/05/16
I think that is backwards..
Cjw3
14:41:22 04/05/16
Re: I think that is backwards..
tinner
17:11:34 04/05/16
tinner
17:30:28 04/05/16
Metacom
18:18:12 04/05/16
tinner
18:24:52 04/05/16
Re: Re: Re: no start after Plenum pull.
Metacom
18:28:48 04/05/16
Criss crossed the fuel in & out hoses. (n/m)
18:58:07 04/05/16
Also make sure CAS & PTU connectors are plugged in (n/m)
18:59:13 04/05/16
tinner
22:13:02 04/05/16
Clean CAS & PTU connectors even if you didn't mess w. them. (n/m)
00:34:08 04/06/16
Also did you remove the fuel pump relay before plenum pull? (n/m)
00:34:50 04/06/16
Re: Also did you remove the fuel pump relay before plenum pull?
tinner
02:08:15 04/06/16
Did you check the two connectors next to the fuse box? (n/m)
itsa300zx
08:31:05 04/06/16
tinner
15:45:25 04/06/16
Metacom
19:02:48 04/06/16
Balance tube 'O' rings ? (n/m) -
ttz'in (norcal)
00:13:46 04/07/16
Re: Balance tube 'O' rings ?
tinner
00:27:55 04/07/16
Re: Re: Balance tube 'O' rings ?
Metacom
01:01:39 04/07/16
What aren't you getting, spark or fuel ?? (n/m)
ttz'in (norcal)
01:16:03 04/07/16
Large vacuum leak would be my guess like Metacom
doug8867
06:38:58 04/08/16
Also make sure the large throttle body hoses are
doug8867
06:40:38 04/08/16
Re: Also make sure the large throttle body hoses are
tinner
10:46:31 04/09/16
